06-23-2024 06:49 PM in
WearablesI lost the charging case for the galaxy buds 2 pro is there an alternative to buy only the charging case?
06-23-2024 07:32 PM in
WearablesIf your problem solved then Mark is as solved by 3 dot clicking.
06-24-2024 08:36 AM in
WearablesDear Samsung Member,
As per your query, we would request you kindly visit the service center or Samsung store and they will provide you with all the information in a better way regarding this.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
You can locate your nearest store locator with this given link:
https://www.samsung.com/in/storelocator/
03-16-2025 08:11 PM in
Wearablesdid you found the case or got replaced with new case in samsung service center..?
