Esim activation problem
(Topic created on: 08-31-2024 09:50 PM)
pradeep_subramani
Beginner Level 4
Wearables
I've recently brought Samsung galaxy watch 4 classic LTE and tried to add airtel esim in my watch but i can't add it. Does anybody faced it?
8 Comments
Wearables
Visit to airtel office they will do it
click2share
Wearables
Esim will not work for airtel prepaid u need to upgrade to pospaid else activate jio prepaid
cs_member10
Wearables
Dear Samsung Member,
Activating the Galaxy Watch’s mobile network: You can receive calls and messages on your Galaxy Watch without mobile devices and also use various other services through the mobile network after activating it.
1. Check that the service providers of your Galaxy Watch and mobile device are the same. The connection method may vary depending on the service provider and region.
2. The mobile device must be connected to a Wi-Fi or mobile network.
3. You can activate the mobile network only when you use a mobile device running the Android operating system 5.0 or later and with 1.5 GB of RAM or more.
4. If the mobile network cannot be activated properly, contact your service provider. Als, the E-sim should be prepaid.
5. While connecting your Galaxy Watch to the mobile device, activate the mobile network on the Mobile service for your watch screen.
6. On the Galaxy Watch’s Apps screen, tap Settings → Select Connections → Select Mobile networks and follow the on-screen instructions to complete the connection.
7. Launch Galaxy Wearable on your mobile device, tap SETTINGS → Select Mobile networks, and then follow the on-screen instructions to complete the connection.
click2share
Wearables
Prepaid airtel not supporting. Check details on airtel website 20240902_141222_1000139002_1725266736.jpg
md1hunox
Beginner Level 4
Wearables
Didn't work on Airtel prepaid for me either. With jio prepaid it worked effortlessly.
Sirius7
Wearables
Same issue
Wearables
Wearables
2682🙏,7
