02-10-2024 07:55 AM in
Unpacked 2025- Mark as New
02-10-2024 07:56 AM in
02-10-2024 08:03 AM in
02-20-2024 02:49 PM in
Unpacked 2025Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Galaxy device sound issue:
Clear Sound Picker data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search Sound Picker>>Tap on storage>> Clear data of Sound Picker.
Clear SoundAlive data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search SoundAliver>>Tap on storage>> Clear data.
Clear Adapt sound data: Settings>>Apps>>Filter and sort>>Enable "Show system apps">>Ok>>Search Adapt Sound>>Tap on storage>>clear data
Galaxy device hang issue:
Kindly check the RAM in your device:
Path: Settings > Battery and device Care > Memory
The device's RAM should be free to improve performance. So clear the RAM once a day
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue persists kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
