battery problem
(Topic created on: 01-07-2021 05:02 PM)
hasrithNayak
Tech Talk
Hi I'm purchasing  last December/2020 sumsung galaxyM31  battery backup   6000 mah but battery  powered  decrease with in 10 hrs 100% to 10% so I need solution wat can ido
9 Comments
Ehsank
Tech Talk
10 hrs os not bad, not this is not an issue
Viki100420
Tech Talk
10hr ki jeetod mehnat karvayi hogi smartphone se😂
hasrithNayak
Tech Talk
wt not bad 4000mah battery almost above 15 hrs so 6000mah battery below 10 hrs how can say you not bad
Viki100420
Tech Talk
It depends on tasks performed and power efficiency of processor not only battery capacity🤷
Ehsank
Tech Talk
15hrs 4000 mah? which mobile dear
Tech Talk
try running a YouTube video for 10hours on a 4000mah phone
https://youtu.be/wMWC18whtc4
hasrithNayak
Tech Talk
mobile purchasing just 1month i need changing mobile or battery
Ritu321
Tech Talk
It depends upon usage.And if U are a light user then go to a service center for Your battery inspection. If your mobile gives 10hr backup with screen on then its not bad
Samsung_Support1
Tech Talk
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
