There is wifi problem in my S20 ultra after Android 12 One ui4.
(Topic created on: 01-07-2022 09:38 PM)
Parv43100
Tech Talk
There are many wifi network  avaible but always shows Poor quality  of Network.
16 Comments
Parv43100
Tech Talk
I am talking about wifi network.
On my other mobile wifi network is working properly from same wifi network but when i try to connect my S20 ultra to same wifi then always shows there is no internet in wifi.
SamPro
Tech Talk
I am facing exactly same issue. And it is something related to the software which states that if wifi network connectivity doesn't improve then it will keep using mobile data. But the fact is other phones are running absolutely fine. IPhone 12 in the same place, with same ssid stays connected without any issue. It is not network or wifi antennae, it is software issue.
Parv43100
Tech Talk
Yes ,i am facing the same problem
SamPro
Tech Talk
I have posted in feedback section. Seems they are not considering it. Please post it in the feedback section. More we complain, tendency to consider will increase.
Tech Talk
Same problem brother in my s21 ultra
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please perform the below mentioned steps to resolve the issue:
* Forget the Network: Go to apps screen >Settings >Connections > Wi-Fi >Wi-Fi network >Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Parv43100
Tech Talk
I already have used the above method but still problem is not solved
