Slow speed on my A34 5G while using wifi
(Topic created on: 11-01-2024 09:36 PM)
user963
Tech Talk
I'm getting very slow speeds using wifi on Samsung A34. I'm getting less than 100mbps speeds. I have a plan of 300 mbps, but still, speeds are not going above 200 mbps
On other phones, I checked i'm getting above 250 mbps, but on Samsung phones, I'm getting slow speeds. I reset the wifi settings, but still, the issue is not solved
I have called to customer care also but issue is not solved
6 Comments
Sowish
Tech Talk
Same issue I am facing
user963
Tech Talk
Any solution u found?
Sowish
Tech Talk
Nope
cs_member10
Tech Talk
Dear Samsung Member,
● Kindly reset the network settings. Settings> General Management> Reset> Reset Network Setting.
● Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
● Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
● Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
● Kindly check and disable the Airplane/Flight Mode on your device.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
Sowish
Tech Talk
This didn't work!
user963
Tech Talk
I did all the steps but still same issue
