Resolved! Solved
Problem with camera and notification access indicator
(Topic created on: 06-19-2025 06:06 PM)
Not applicable
Tech Talk
After the one ui 7 uptade in my phone(M35) after 1 month ar around I noticed that the camera and microphone indicator remains on and when I see it in control panel there's nothing.
It doesn't go even after closing all the apps from recent menue even after stopping background working apps. But when I restart my phone it goes but after 2-3 days it reappears
Has enyone else also noticed this or can tell any solution to it.
Musabbir_Zone
Tech Talk
This issue appears to be a *One UI 7 bug* affecting *privacy indicators* (camera/microphone usage) even when no apps are actively using them.
*Try these solutions:*
1. *Check App Permissions:*
- Go to *Settings > Privacy > Permission Manager*
- Review apps with *Camera* and *Microphone* access
- Revoke access from apps you don’t trust or use
2. *Clear Cache:*
- *Settings > Device care > Storage > Clean now*
- Also, go to *Settings > Apps > Camera/Microphone-related apps > Storage > Clear cache*
3. *Update System Apps:*
- Open *Galaxy Store > Updates* – make sure *Device Care, Privacy Dashboard, and Camera* apps are up to date
4. *Submit a Bug Report:*
- Open *Samsung Members > Get Help > Error Reports > Camera/Privacy*
- Describe your issue and attach logs (best within 5 minutes after noticing the bug)
"If this helps, feel free to mark as solution!" ❤
4 Comments
nikhilkoli9ó
Tech Talk
No, mine m35 is fine
Musabbir_Zone
Tech Talk
2. *Clear Cache:*
Not applicable
Tech Talk
Thanks a lot 😊
cs_member10
Tech Talk
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
