Note9 battery bulge
(Topic created on: 10-11-2020 07:41 PM)
srihithbandaru
Tech Talk
Anyone facing issue battery bulge issue on mobile phones??
7 Comments
Not applicable
Tech Talk
change your battery
Tech Talk
went to store, they said it is common on phones and need no battery change as the battery life hasn't discharged
Anikroyale
Tech Talk
Go to an official service center and change your battery, even if they tell it is fine. It might be too dangerous to use it.
Tech Talk
sure, thanks for the suggestion
Not applicable
Tech Talk
change the battery its too dangerous to use
Samsung_Support3
Tech Talk
Dear Samsung Member,
We request you to kindly visit the service center for physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Pappu12345678
Tech Talk
note 9 battery drain issue
