J7Pro
(Topic created on: 04-09-2020 12:42 PM)
BabuJanardhanan
Tech Talk
Back button in J7 Pro is not working. Any suggestions to rectify
Samsung_Support3
Tech Talk
Dear Samsung Member,
Check device in safe mode: Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key.
To exit safe mode: Restart your device.
If issue still persist, kindly send us log file through error report section from Samsung Member within 15 minutes of issue occurrence, this will help us to assist you better. (Samsung member > Get help > Send feedback > Error report > Select the issue).
