Resolved! Solved
Is there a problem if somehow I overcharged my phone?
(Topic created on: 08-19-2021 04:45 PM)
Gourav_Sen
Tech Talk
Anyone....(overcharged for only 30-40 mins)
5 Solutions
Not applicable
Tech Talk
No. Phones generally trickle charge once it reaches 100%. It will harm if you trickle continuously for long run without discharging the battery.
Tech Talk
No not at all..now a days smartphones are smart enough to tackle such overcharging stuffs..
Not applicable
Tech Talk
You know mobile disconnected automatically when it overcharged
Ones check !
After reaching max level it will turn off
Tech Talk
No, today's phones are capable for handling overcharging. It is totally normal. Don't repeat these too much because this may decrease the battery backup slightly.
If you find this helpful kindly click on the three dots and click accept as solution.
DrQaisar
Tech Talk
No there is an intelligent power management system in the battery and phone itself.
Battery management consists of three parts: charge monitoring, protection, and control. Battery monitoring and protection ICs are usually supplied with the battery itself. However, charge control is part of the portable device. when the battery is charged to 100% , the power management integrated circuits (PMICs) which are very intelligent manages the flow of charge.
Factors such as recharge cycles, aging, and temperature can degrade the performance of the lithium-ion battery over time.
I hope that is helpful. Please press like button 👍
13 Comments
Not applicable
Tech Talk
Gourav_Sen
Tech Talk
Ok thanks bro🙂
Not applicable
Tech Talk
My pleasure 😊
Tech Talk
Gourav_Sen
Tech Talk
Ok thanks 😊
Not applicable
Tech Talk
Ones check !
Gourav_Sen
Tech Talk
Ya it shows green color filled battery icon
Not applicable
Tech Talk
Yes !
Tech Talk
