I am having a wifi issue,need help
(Topic created on: 12-12-2019 09:00 PM)
DrJakePj
Tech Talk
Guys do anyone know how to fix the wifi  which gets cut off when downloading apps fro. Play store, or Samsung app store,I am able to surf  through internet, and watch videos,but not able to download for the app stores ...wifi gets cut off and turns back on
18 Comments
pranavchawla
Tech Talk
vpn only change the location didn't interrupt the wifi aur mobile data but they can slow down the net only
DrJakePj
Tech Talk
yeah but when I turn on the vpn I get a stable connection....
darkf1ber
Tech Talk
yes. u have accidentally set the palystore setting to download and update over wifi. change it to download over metered or mobile connections.
DrJakePj
Tech Talk
it's in metered or mobile connection bro still facing the issue
Girishankar
Tech Talk
can connect to different wifi and check are u able to download from play store?
DrJakePj
Tech Talk
it's odd but am able to do so ,...
Girishankar
Tech Talk
jus a isolating issue bro
DrJakePj
Tech Talk
hey I fixed it ,had to deactivate the wmm in the router settings,... anyways thank you so much for your time bro cheers!!!!!
Girishankar
Tech Talk
thank you bro and welcome
