Help me to fix or solve this problem
(Topic created on: 08-26-2022 01:25 AM)
Shekhar magar
Tech Talk
I have been some multi touch issue seen from some days in my mobile phone.   when I touch my mobile screen more than 2 finger  it can not touch or don't do any response.  I recognize this problem when I play pubg . I play with 5 finger but now this could not play or do anything dueto this problem.. if you have any solution than please help me🙏🥺
11 Comments
Bwin31
Tech Talk
Download and install a Multi Touch Tester from Play Store! &check how many touch points device can register
Shekhar magar
Tech Talk
Some time it show 10 multi touch and most of the time it show only 2 point....
Bwin31
Tech Talk
Okay...! Have you recently updated your phone.. prolly this month?
Shekhar magar
Tech Talk
Yes, in june 1
Bwin31
Tech Talk
Hmm! Does after the update? You started facing this issue?
Shekhar magar
Tech Talk
I think 🤔 yes..
Because before update that issue doesn't occur.
So
Bwin31
Tech Talk
Then you have to wait till the Next update, which will gonna fix this mess.or you can try resetting the device! (Better to backup before reset, because it will clear your whole phone storage)
Shekhar magar
Tech Talk
I already do that resetting the device ...
It's doesn't work..
I think...
I should wait up to next update...
But when shoud be the next update
Bwin31
Tech Talk
Can't say for sure, what is your device model?
