Resolved! Solved
Does it matter using mobile while charging?
(Topic created on: 11-23-2019 09:36 PM)
TheArpppSingh
Tech Talk
Pls anyone can help me by replying that... will it harm our mobile if we use them while charging (not calling but only using other apps playing game)?
Resolved!
18 Comments
TheArpppSingh
Tech Talk
accepted bro
Tech Talk
If You Have Any doubt Just Comment On My Post As Soon As I Will Clarify
JackDorsal
Tech Talk
please don't use your phone while charging. In simple sentences it is very harmful for your phone, specifically for battery.
yea, while charging just seeing some aap info for a while, its ok. Its effects may not be so noticeable, but playing games on charging will just kill your battery life as well decrease phones performance.
TheArpppSingh
Tech Talk
thank you for ur response Man🙏
Debashisllc
Tech Talk
do not use while charging
TheArpppSingh
Tech Talk
ok bro🤘
Francis
Tech Talk
it's a sheer myth!
There is no danger in using your phone while it’s charging. This myth comes from fears about batteries overheating. Lithium-ion batteries can be dangerous if they have any type of manufacturing defect, but this is rare. However, if your phone is ever excessively warm (while charging or not), get it checked out immediately.
While you can use it during a charge, having the screen on or apps refreshing in the background uses power, so it will charge at half the speed. If you want your phone to charge more quickly, put it in airplane mode or turn it off. Also, charging from a wall plug is always faster than using a computer or car charger.
TheArpppSingh
Tech Talk
thank you.
but some apps started hanging down.
Francis
Tech Talk
Performance and battery level doesn't have any reliance unless if your batter is below 10%.
if you are facing performance issues, check if your phone is in battery saver mode and also, uninstall any battery apps that manages your battery
