Resolved! Solved
Does it matter using mobile while charging?
(Topic created on: 11-23-2019 09:36 PM)
TheArpppSingh
Tech Talk
Pls anyone can help me by replying that... will it harm our mobile if we use them while charging (not calling but only using other apps playing game)?
6 Solutions
FallOut007
Tech Talk
playing games matters a lot... its bad for battery's health.
Ravi0883
Tech Talk
its better not to use your phone while charging
Tech Talk
While charging the Regulator chip Does Two functions while using the when charging
The chip can able to do only one function at a time arranging the Anode and the cathode in the battery
when it is used the battery is stressed and it may lead to lack of battery life amd battery health
And the Processor and motherboard gets heating issue
JackDorsal
Tech Talk
please don't use your phone while charging. In simple sentences it is very harmful for your phone, specifically for battery.
yea, while charging just seeing some aap info for a while, its ok. Its effects may not be so noticeable, but playing games on charging will just kill your battery life as well decrease phones performance.
Debashisllc
Tech Talk
do not use while charging
Francis
Tech Talk
it's a sheer myth!
There is no danger in using your phone while it’s charging. This myth comes from fears about batteries overheating. Lithium-ion batteries can be dangerous if they have any type of manufacturing defect, but this is rare. However, if your phone is ever excessively warm (while charging or not), get it checked out immediately.
While you can use it during a charge, having the screen on or apps refreshing in the background uses power, so it will charge at half the speed. If you want your phone to charge more quickly, put it in airplane mode or turn it off. Also, charging from a wall plug is always faster than using a computer or car charger.
18 Comments
THEDOCTOR1
Tech Talk
no
TheArpppSingh
Tech Talk
FallOut007
Tech Talk
TheArpppSingh
Tech Talk
ya i think so thank you
Ravi0883
Tech Talk
TheArpppSingh
Tech Talk
ok tysm
Ravi0883
Tech Talk
Tech Talk
TheArpppSingh
Tech Talk
so Seems better to avoid using during charging.
ok thank you man
