Common Problem Common Solution ft. One UI 6
(Topic created on: 04-30-2024 11:45 AM)
Tech Talk
If you are facing the following problems and you have updated or are on One UI 6, then their is a simple fix.
1. Dialler codes not working.
2. APKs not installing.
3. USB debugging not working.
The fix is to turn off Auto blocker.
To do so,
Go to Settings > Security and Privacy > Auto Blocker > Turn it off.
How to turn off auto blocker.
Thanks 😊
2 Comments
cs_member10
Tech Talk
Dear Samsung Member,
Thank you for sharing this, if you have any further queries kindly feel free to get in touch with us.
Phoenix__1
Tech Talk
I always knew that in high range devices apks dont get installed for security reasons , but didnt knew that it can be turned off.
