Battery warning level
(Topic created on: 02-25-2021 08:35 PM)
abinashg
Tech Talk
Please provide the settings to change the battery warning level so that we can change it from 10,15 or 20%. Right now the S21 ultra default is 15%. And also the moment it reaches to warning level it should automatically switch to powersaving mode.
2 Comments
Ehsank
Tech Talk
about shifting to power saving if you set to adaptive battery and adaptive power saving then it will change automatically
Ehsank
Tech Talk
further you can do few more settings by s power planning
you can check out my post on it
https://r2.community.samsung.com/t5/Tech-Talk/S-Power-Planning-More-Control-on-Battery/td-p/6669948
