S Power Planning: More Control on Battery
(Topic created on: 01-09-2021 10:49 AM)
Ehsank
Tech Talk
S Power Planning provides you, More controls on your mobile battery, It can plan to use your device to a maximum without severely restricting normal usage of the phone
App link from galaxy store 👇👇 (its Samsung Own App)
http://apps.samsung.com/appquery/appDetail.as?appId=com.samsung.android.app.powerplanning
1. Reserve battery for calls;
Reserve a portion of the battery to calls.
2. Extended Battery Time;
Select a battery level to extend battery life, Phone manages various settings accordingly in the background.
3. Forward Calls when No battery;
when the battery runs out the device ,forward Incoming calls to preset phones number, can also send text to that preset number as alert.
22 Comments
Suyo
Tech Talk
good stuff Ehsank!
Ehsank
Tech Talk
thanks dear 🙏🙏
Albugoo
Tech Talk
us post wale to sach me bhadak Gaye.....jaldi jaldi apni comments delete karo waha...mai to delete karne chali socha gali sun'ne se pahle tumhe bhi bata du😬😬😬😬
Ehsank
Tech Talk
really🙄🙄
Albugoo
Tech Talk
are us waqt wo bole hi aayse phir maine sorry kaha to bole ki apne to baat dil pe le li mai to bus व्यंग kar raha tha.....pahle dara diya phir व्यंग kar rha tha😅😅🤣🤣
Ehsank
Tech Talk
dene do main main udhar jaonga hi nahi 😁😁😁😁🤣🤣🤣🤣
jokes apart, kar dunga abhi thanks batane k lyie
Albugoo
Tech Talk
aab jarurat nhi hai😊
Ehsank
Tech Talk
really🙄🙄 itni jaldi aapne sort out bhi kar lya,👏👏
Albugoo
Tech Talk
