Resolved! Solved
Battery drain issue
(Topic created on: 12-24-2019 08:43 PM)
Anikroyale
Tech Talk
I have recently seen many people posting about battery drain issue. Most of them are from India and nearby regions. I would like to share something I recently found while using device care. A notification popped up saying that cold weather conditions may temporarily increase battery drain but the battery will recover when it goes to warmer temperatures. As winter is here, the cold temperature could be a reason for decreased battery life, but as always, I am not 100% sure that this is the reason. Thank you for sparing some time reading this.
Not applicable
Tech Talk
yes but not for all time...software glitches also responsible to drain batteries
4 Comments
Arnav_Kalia
Tech Talk
I think we face a lot of battery drains because cellular network isn't the best in India. Whenever there is low or fluctuating network, the battery consumption increases as its constantly searching for better network. If your location services are always on, then this increases battery consumption even more if network is low.
But very interesting to read about weather affecting battery drain!
Anikroyale
Tech Talk
Hey, I was talking about this! Although your point is also valid!
Not applicable
Tech Talk
Anikroyale
Tech Talk
Ya...that's also the fact
