Tab S9+ slow charging speed issue.
(Topic created on: 08-03-2024 01:45 AM)
DeltaSagittarii
Tablets
I have been using this device for past 4 months now. The charging speed was very good initially and used to charge at around 40W using by 45W charger. Ever since the 6.1 update I have observed that the resting charging speed is around thirteen or 14W and very rarely peaks above 20W.
Is anyone else experiencing a similar issue? If yes, is there a resolution to it?
3 Comments
goodthings
Tablets
Kindly reset factory data with backup then try to it's again also charge your's device in cool atmosphere also during charging turn off internet then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Tablets
Your's most welcome to here.
cs_member10
Tablets
Dear Samsung Member,
As per your concern, we request that you kindly follow the steps to resolve your issue.
Galaxy device slow charging issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Kindly check if ''Multiple applications'' are running in the background of the device.
When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
