Sound can't be heard during calls while using freebuds!
(Topic created on: 10-24-2024 08:49 PM)
Yasin129183
Tablets
Hello, as a user of Samsung Galaxy S9 fe plus, I am facing some problems regarding sound issue during calls. While connected to my freebuds I can not hear any sound through it!
I hope you understand the situation and fix this issue soon.
Thank you.
cs_member10
Tablets
Dear Samsung Member,
● Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
● The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● You can reset your device by following the steps from the below link.
Kindly check the same headphones with another phone or other headphones/ buds with the same mobile, if still facing issues, please visit the service center for a physical inspection of your device and headphones. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
