Samsung Tab A8 Battery Drain | Subject : Battery draining rapidly below 30%
(Topic created on: 03-21-2024 06:38 PM)
Yuuto
Tablets
Hello everyone, I'm here to request assistance on a problem that I faced regarding my Samsung tab A8 model SM-X200 (WiFi)
So what my tablet does is it that when it reaches a Battery percentage of 30% , it rapidly decreases percentage by percentage quickly.
For eg :- from 30% to 29% to 28% to 27% in just 10 to 40 seconds.
This has happened several times now
  • I calibrated my device before, where you let it get to 0% and charge it all the way to 100 and leave it for a few hours.
  • Software is up to date
  • Doesn't use the tab heavily.
  • Majority of the apps are in deep sleep.
  • Brightness is always low
Please do tell me why this is happening. I am quite worried. Is a similar situation happening to others as well? Is this related to a software bug? Does this have anything to do with standby time?
11 Comments
goodthings
Tablets
Yuuto
Tablets
How can I send error logs, can you please explain, also is it really a software bug, is anyone else facing this?
goodthings
Tablets
Please go to Samsung Members App main page, click support, click feedback, click error report then follow instructions on screen. Thanks.
goodthings
Tablets
Your's most welcome to here.
cs_member10
Tablets
Dear Samsung Member,
We want to inform you about the Samsung Members app (Battery Status (Battery life + Battery Capacity).
You can check the "Battery Status (Battery life + Battery Capacity)" test using the Samsung Members app.
Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
We would like to inform you about the standard charging procedure (charge in one go instead of charging many times as it affects the life span of the battery and battery performance).
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level.
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps.
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/Samsung-galaxy-mobile-how-to-perform-a-factory-res...
IAmSurya
Tablets
It's true, from last one year, worst experience with this.
Yuuto
Tablets
Is this happening to you as well? I tried the solutions stated yet I still faced this issue again today.
My battery was 33% last night, when I woke up today it was 26%.
Then it got rapidly decreased to 17% in a matter of 3 minutes.
IAmSurya
Tablets
Yes, same here. I'm not happy with this Tab A8.(In this battery 🪫 dropping)
IAmSurya
Tablets
from last 1 year
