Fast battery Drain issue
(Topic created on: 12-15-2024 03:06 PM)
nk023
Tablets
Getting less SOT in Tab S9 after October Security update
3 Comments
DASTIDAR
Tablets
Check if YouTube is using battery in the background. If so, optimise it.
mksingh98
Tablets
Clear the data of youtube
cs_member10
Tablets
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
