Battery drain
(Topic created on: 06-04-2025 07:45 PM)
rudetressure
Tablets
Serious battery drain is happening after one ui7 update !!!
Please fix this issue otherwise
3 Comments
Not applicable
Tablets
Check which app consuming most of the battery
BiRdMaN
Tablets
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
cs_member10
Tablets
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
