Resolved! Solved
Edge panel not visible
(Topic created on: 04-20-2026 10:29 PM)
Vínìt
Tablets
i am using tab s8 with one ui 8 Android 16. edge panel is not visible and also not working. while modifying it through setting it got visible but as i got to home screen it again vanishes.
please let me know if someone facing same problem or having any solution.
#edgepanel #problem #tabs8
sumitkhemnar
Tablets
Agar settings mein dikh raha hai par home screen par gayab ho jata hai, toh ye steps follow karein:
​1. Edge Panel App Cache Clear karein
​Edge Panel khud ek mini-app hai jo background mein chalti hai. Ise reset karna zaruri hai:
​Settings > Apps.
​Upar filter icon par click karke "Show system apps" ON karein.
​Search karein "Edge panels".
​Storage mein ja kar "Clear Cache" aur "Clear Data" kar dein.
​Isse aapka panel reset ho jayega, ab wapas settings mein ja kar ise ON karein.
​2. Check "Appear on Top" Permission
​Android 16 mein privacy settings bahut strict hain. Check karein ki Edge Panel ko system ke upar dikhne ki permission hai:
​Settings > Apps > Special Access (3 dots mein milega).
​"Appear on top" select karein.
​List mein Edge panels ko dhundein aur toggle ON karein.
​3. Disable "Taskbar" Conflict (For Tablets)
​Tab S8 mein ek niche "Taskbar" hota hai. Kayi baar Taskbar aur Edge Panel ek saath screen space ke liye "clash" karte hain:
​Settings > Display > Taskbar.
​Ek baar Taskbar ko OFF karke check karein ki Edge Panel wapas aata hai ya nahi. Agar aa jata hai, toh ye resolution scaling ka bug hai.
​4. Handle Settings Adjust karein
​Kayi baar handle ka color ya transparency aisi hoti hai ki wo background mein "Camouflage" ho jata hai:
​Settings > Display > Edge panels > Handle.
​Transparency ko Low (yani dark) karein aur Width ko Thick karein.
​Iska Position (Left/Right) change karke dekhein.
📝 Expert Note for Community:
​"Bhai, Tab S8 par One UI 8 mein Edge Panel ka vanishing issue aksar System UI scaling ya Display Overlay permissions ki wajah se hota hai. 'Edge panels' app ka data clear karein aur 'Appear on top' permission check karein. Agar Taskbar ON hai, toh use ON/OFF karke toggle karein. Agar help hui ho toh 3 dots (⋮) par click karke 'Accept as Solution' mark kar dena! Shukriya! 💙🚀"
3 Comments
sumitkhemnar
Tablets
​Settings > Apps.
Vínìt
Tablets
thanks for response and genuine advice.
one thing you missed is restart the device 😅
cs_member10
Tablets
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
