AbhijithAshok
02-27-2023 10:05 PM (Last edited 02-27-2023 10:06 PM ) in
Tablets
Hi mates, I'm new to Galaxy Tab device and owned Tab S8. I've noticed few things like edge panels and edge lighting, the things are I'm unable to add any new edge panels from galaxy store but my Note 10 has an option to add edge panels from galaxy store...
Edge lighting has no effects around the corners of the tablet and effect is visible only at the top of the display whereas Note 10 has around the display...
I'm attaching screenshots of my Tab and Note 10
So is the function has any limitations on the tablet comparing to smartphones? Or am I having any defective unit...?any clues...? Thanks in advance
2 Comments
Vishky
03-07-2023 08:29 AM in
Tablets
I also recently bought this Tab S8, firstly, it's not amoled so, we are not - going to get AOD & lighting and secondly edge panel is also not fully functional it just shows some of the apps , No clipboards, No calculators etc.
And I'm also having problem with battery too, as soon as my battery reaches 5%, it will drop to zero immediately & gets switched off. Initially, I'm facing some heating issue too, my tab gets warm while multi tasking but later I come to know that some of the apps are using more RAM so I reinstalled them, and got a new back Cover, now it's okay. But that 5% thing is still there.
And one more issue which I faced that, one day I kept my device at 93% battery in morning and after returning home in evening I saw it gets drained to 74%, my device is wifi version and my wifi was also off. I told about this issue to samsung Customer care and they told me to visit Service Centre but I didn't go.
s23ultraGuy
04-02-2024 10:32 PM in
Tablets
Same thing on Galaxy tab S9, cannot add any new custom edge panel like "control center" it can be added on phone but on tablet, No way! 😔
