09-29-2024 11:00 PM in
Tablets- Mark as New
09-29-2024 11:13 PM in
09-30-2024 10:33 PM in
09-30-2024 10:36 PM in
10-02-2024 09:41 AM in
TabletsDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
10-02-2024 03:42 PM in
Tablets
