Battery Drain After one UI 7
(Topic created on: 2 weeks ago)
BhushanS24
Samsung Health
Battery issue especially after one UI 7 update, using S24 for normal routine with screen time of around 6 hours, the battery shows 19 hours on full charge which is very less, expectations are atleast 24 hours or more
6 Comments
goodthings
Samsung Health
goodthings
Samsung Health
Your's most welcome to here.
cs_member10
Samsung Health
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
Shonzzzz
Samsung Health
Nice posthttps://r2.community.samsung.com/t5/Galaxy-Gallery/s24-fe/td-p/19464538?src=ShareByUserCM Please like my post
Shonzzzz
Samsung Health
Shonzzzz
Samsung Health
