Camera problem
(Topic created on: 11-27-2024 06:38 PM)
kirankumar2020
Pune
Selfie problem wrong side images create
3 Comments
Wodehouse
Pune
Open Camera
Go to settings
Look for "save selfies as previewed"
Disable the option
Exit.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
cs_member10
Pune
Dear Samsung Member,
We also request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
cubesquare
Pune
One ui 6.1.1
S22 ultra
While talking group selfies , it only focus on front subject
Example
Out of 6 member
it focus front subject 1. All the time.
Group selfies looks always blurred images
