battery problem after update
(Topic created on: 01-07-2019 01:21 PM)
sonijiS20p
Others
How many samsung mobile user facing  battery and slow charging related problem after any kind of update such as security patch or major os update?
My mobile battery performance is very much degraded after oreo update.
10 Comments
anilpss
Others
please factory reset your phone it eliminate the issue
sometimes apps may not get optimise correctly that's the reason you face these issue
sen001
Others
Oreo is draining more battery then Nought in S7. Last 2 updates has also detorioted battery performance. Android system is highest battery consumers, which in not normal. Normally it should be the Screen. Thats the story of Software and S7, for many months.
sonijiS20p
Others
same bro last two security patch update also couldnt solve this issue.
sonijiS20p
Others
after oreo, s7 was suffered of too much battery drain issue till three month.
Bapon1
Others
please restart your phone and full charge
rishi59
Others
i have updated on s9 and i didn't face battery chaege but battery drains too quickly.. with help of service centre i got back to back to older version of os
sonijiS20p
Others
mostly samsung phone facing same problem after update.
Others
ya its slowly going battery
admin_
Others
Thank you for being a part of Samsung community. We apologize for the inconvenience caused to you. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
