Samsung smart view connection problem.
(Topic created on: 09-24-2024 12:00 AM)
TanjimBiswas
Others
When I turn on Samsung smart view from my phone then go to screen cast option from my Windows pc then my phone name shows but when I try to connect it doesn't connect and sometimes it connects. I can always connect it without any problem?
4 Comments
cs_member10
Others
Dear Samsung Member,
As per your concern, Kindly perform the following steps to resolve your issue by the given link:
https://www.samsung.com/in/support/mobile-devices/troubleshooting-a-problem-when-using-smart-view/
sadekin
Others
Give permission
eamesh
Others
Samsung smart view Update
neerajcrazy
Others
On my phone TV is showing but smart view connection not happening. Previously it used to connect
