Samsung S10 Lite - Display problem(Manufacturing defect)
(Topic created on: 10-26-2021 10:48 PM)
Sherwinjo
Others
 I'm currently using Samsung S10 lite. It has an amoled display, tho the color quality and the picturization of blacks are not quite good. There is a breakage in pixels. Is it a manufacturing defect or is it totally normal?
 If so what can I do about it?
12 Comments
sachin7575
Others
Same problem here
Sherwinjo
Others
What did you do?
sachin7575
Others
It's software problem.. maybe bug.. wait October update
Sherwinjo
Others
Hope so.
iamrohitkm
Others
Check in service center once.
Sherwinjo
Others
Okay.
IcyJay30
Expert Level 4
Others
Black crush issue i think
Sherwinjo
Others
What can I do to correct that defect?
ajitsaria
Others
Submit your problem through error reporting with video of the screen recorded from the inbuilt screenshot function
