Samsung Galaxy S23 will come with bigger battery than S22
(Topic created on: 09-24-2022 03:26 PM)
TheFastestIndian
Others
Samsung Galaxy S23 is the next Galaxy S series that will launch in the first quarter of 2023. So far, several rumors, leaks, renders, and more information surfaced online which revealed its design, bezel size, camera setup, and more. In a recent development, the company is planning to increase the battery capacity of the upcoming Samsung Galaxy S23 series smartphones.
According to the information (TheElec), the South Korean tech giant will use a bigger battery in the next generation Galaxy S series smartphones as the company is boosting the capacity of the battery by 5%, however, the size of the battery remains the same.
As of now, the increase in battery capacity for all models is yet to be confirmed. The Base and Ultra models may maintain their battery capacity, while the Plus model may have increased battery. The battery of the Plus model is expected to be 4700 mAH.
Expanding the battery capacity of any smartphone is not an easy thing, but with increasing technology, users want to use such smartphones which have good battery backup.
So to expand the battery capacity, Samsung is using stacking technology this time, stacking the battery internal material layer by layer like a ladder to expand the capacity of SDI pouch-type batteries.
In mid-September 2022, an alleged battery bearing the Galaxy S23 Plus model number EB-BS916ABY appeared on the Security Korea certification site. The Chinese firm ATL (Ningde Amperex Technology Limited) manufactured the battery for the Galaxy S23+ model.
6 Comments
Not applicable
Others
Still they will get <5 hrs of SoT 🤡.
Others
Software optimization is required at deeper level, my friend
dissosa
Others
Definitely >5 hrs of sot
Not applicable
Others
F off from here before I abuse you to death.
dissosa
Others
I never hold back...i will return the favour 100 times harder than u
Others
Hoping for the best
