Not able to connect my M70D monitor using Type C cable
(Topic created on: 08-17-2024 08:24 PM)
Ramesh_07
Others
Yesterday got my new Samsung M70D(LS32DM700UWXXL) Monitor, I can able to connect my monitor with my laptop(Dell Latitude 3520) using HDMI cable. but I'm not able to connect my monitor with my laptop using Type-C cable. Actually It's not at all detect my monitor. It's just charging my laptop only. I'm not able to share my laptop screen to the monitor using Type C Cable.
Monitor: Samsung M70D(LS32DM700UWXXL)
Laptop: Dell Latitude 3520
Type-C Cable: Samsung type-C to Type-C Cable, UGREEN 3M USB C to USB C Cable 100W Fast Charge CableWhatsApp Image 2024-08-17 at 7.19.21 PM.jpeg
3 Comments
Singh_Jot
Others
Dear member.
Please post in plz go help desk rise errorreport for solutions, follow click 3dots right upper corner of this page, click Edit, If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution.For better information
Thanks.
Ramesh_07
Others
Finally, I got the solution from myself only after referring to the product manual.
So, Samsung already mentions in the document that we need a USB Type-C 3.1 Gen2 10G cable (Displayport ALT) at least to share the screen with the monitor using the Type-C cable. In my case, both my Samsung and Ugreen cables, which I mentioned above, won't support the DisplayPort ALT function. So, that's the reason I faced the issue. And currently, I don't have a DisplayPort ALT function cable to test it. But in the below, I will mention the cable that supports the DisplayPort ALT function.
Cable NameUGREEN 1m USB-C to USB-C Cable, 240W Power Delivery USB C 3.2 Gen 2 10Gbps 4K Video Compatible for MacBook Pro/Air, Huawei Matebook, iPad Pro 2020, Chromebook, Samsung Galaxy S20/S10, Pixel (80150V240)
Link:
UgreenIndia_Ugreen USB Type-C 3.1 Gen2 10G cable
Amazon_Ugreen USB Type-C 3.1 Gen2 10G cable
cs_member10
Others
Dear Samsung Member,
We would request you kindly contact the dedicated WhatsApp helpline ( 1800-5-7267864 Operations 24*7 ) they will guide you with the exact information regarding this.
