Resolved! Solved
Charging cable problem
(Topic created on: 07-14-2023 12:01 AM)
levinstan
Others
Bad quality charging cable out of the box little Crack what happen to my friend Samsung
See this quality also this cable very short not 1 meter
cs_member10
Others
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request that you kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
4 Comments
Others
I use 3 year still no issues
levinstan
Others
Out of the box problem
3 years before Samsung give best quality now it was totally disagree
Others
Yes your right I am use A31 but my father buy A52s in the box i have charger but it's quality are poor my A31 charger quality are best
cs_member10
Others
