Camera using flash related issue...
(Topic created on: 11-14-2018 12:05 PM)
playernaresh
Others
Is it normal that the picture, that is captured during night tym using flash, gets the whitish image???
7 Comments
mnh
Others
yes its nornal
YRSS
Others
yes normal
YRSS
Others
keep posting
wasee
Others
Move slightly away from the subject, it will look less obvious.
Shiv9564
Others
Shiv9564
Others
It's normal brother
admin_
Others
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
