Battery power saver
(Topic created on: 04-19-2020 07:30 AM)
Aasif_Saudi
Others
Can anyone explain about adaptive power saving ??
Should I switch off or, on ?
What is benefit by switching on or, off on battery life and phone performance?????
7 Comments
PAULjose
Others
Bro it helps to switch from optimised mode to medium power saving mode automatically based on your usage and in reverse. So you can turn it on if you want to save battery automatically.
ArunDahiya
Others
if you want to save battery then go for it, else it can be annoying at times as it'll change some of the settings on the phone
Ashwin98
Others
Hi Aasif, the advantage of enabling Adaptive power saving is during the unused time of phone. It saves the battery a lot. Try to turn on that mode,bcoz it'll save more battery life
Aasif_Saudi
Others
will it affect the performance???
Not applicable
Others
@ Aasif...no it will not .....only you can't set wqhd display from display settings if you enable that option
Others
It learns your usage patterns and adjust the performance of the device based on these habits, which app you use the most, least used app, put background tasks to sleep, battery charging pattern etc...
Others
Adaptive power saving uses AI to predict your mobile's idle time and then it will set power mode to medium power saving at that time. Draw back of this is that it learns from your usage. So if your use case is exceptional then basically it will never triggers.
I personally prefer using bixby routine to set medium power saving. For that you need to switch off adaptive power saving.
