Battery drainage problem.
(Topic created on: 07-04-2019 08:51 PM)
iamnaveenbisht
Others
Dear Samsung ,
I am facing the same problem of battery drainage with my Galaxy S8 as I was facing before with Galaxy A5 2016. After few updates the battery started draining fast in Galaxy S8 and the same happened with my Galaxy A5 2016 After few software and security patch update. It going down from 10% to 0% like in 15 secs and then switched off.  Is it some kind of marketing strategies of yours so buyers buy your new phones cause their old samsung phones are draining fast. If that so this is very cheap strategy of yours. No one wants to waste money on some kind of pathetic hatdware or else Please make your batteries more durable or release a stable update for this problem. Otherwise you might loose one of your loyal customer from India soon.
There are plenty of other brands with good battery life.
14 Comments
manu1086
Others
same
omgkavi
Others
same
hridoy3323
Others
same here in m10🥺🥺
asarmans
Others
same problem
shubh18
Others
same here in my s8 plus
Not applicable
Others
avoid heat try to cool down the phone . when you get change battery
INDIANCYBER
Others
i THINK its battery problem ya fir ho sakta hai Samsung ne jan buj kar kiya hai isa
INDIANCYBER
Others
merepas A5 2016 hai usme to 20 to 0% 3-4 mints me khatm hota hai
Not applicable
Others
mera toh nahi hota yeh
