Battery drain issues
(Topic created on: 02-29-2020 04:04 PM)
immi007
Others
Battery Drains Frequently
Last Update Date : Mar 27. 2018
If you have the performance issues with your Samsung Mobile device as follows :
 Performance Issue
 Battery Drains frequently
 Battery Discharge while playing games
 Battery Drains when watching movies
 Battery only runs for few hours
Then try each of these steps to see if it helps in improving your phone's performance.
 Checklist
 Check whether Bluetooth, Wi-Fi, GPS, Bluetooth, NFC/S Beam, Tethering
 and Portable Hotspot is turned on when not in use.
 Check whether the brightness of the device is set to minimum or not.
 Smart Features in Flagship phones like Motion UI, Smart Stay,
 Air Gestures, Screen Mirroring etc. will drain battery considerably.
 Check Power Saving Mode (If available)
 Auto Sync of E-mails, App data etc. will drain battery.
 Multiple Applications running in back ground will drain battery power.
 Check the Network Mode 3G (WCDMA) Network mode will drain more
 battery compared to 2G/2.5G (GSM only Mode)
 Network Fluctuation also drains battery.
 Minimizing the back-light time would save battery.
 Follow the standard charging procedure (i.e. charge a fully discharge
 battery in Switch-off mode up to 150 minutes)
 Periodic Software Update through Kies, FOTA or Smart Tool is intended
 to improve the battery life as well
Source Samsung support link
For battery drainage issue follow the given link: http://www.samsung.com/in/support/skp/faq/1101689
(This post is copy pasted from the site.)
Also posted it in tech talks.
