Battery Problem
(Topic created on: 11-02-2019 10:38 PM)
malish
Others
I had been using A6+Pro 1 year . on 28 October I purchased Samsung A70s .the company says its battery capacity is 4500 mAh. but I could use 12 to 13 hours only .where as A6 Plus Pro could be used 36 hours with 3500 MH battery .so so this is very difficult  for me take Power Bank along with the phone all the time I request the company to check the issue and .solve it
3 Comments
Deepak29
Others
YES SAME HERE THE BATTERY DRAINS FAST LIKE ITS HAVING 2500 MAH BATTERY
AgileLories
Others
bro it's depend on screen also may be your current mobile version had QHD display so just decrease resolution and unistall and disable unnecessary application and set Always On Display from Always Show On to Tap to show.
It might be usefull.
malish
Others
My Samsung A70S video and sound not playing together. Sound comes after video. when I approaded service centre, they installed another software. Then video quality very very poor. When updated again repeated the same mistake
