11-21-2018 09:44 AM (Last edited 03-14-2019 10:42 PM ) in
OthersIn order to keep your lithium-ion batteries safe and improve their efficiency, we recommend the following actions:
1 Follow the battery usage, storage and charging guidelines provided in your wireless device’s user guide. Do not open your battery pack.
2 Purchase chargers and accessories that are certified, approved or otherwise compatible with your device. If you see an example of an unsafe mobile device or accessory, please report it immediately.
3 Avoid damaging the battery by not crushing, puncturing or putting pressure on it.
4 Keep the device away from heat sources such as direct sunlight and cooking surfaces. Sustained hot or extremely cold weather or temperatures can also impact your battery’s performance.
5 Keep the battery away from other metal objects like coins and keys since they can impact its electrical connections.
6 Avoid exposing the battery to water, which could cause corrosion.
7 Avoid dropping your device, which could potentially damage the battery.
8 If you plan to store your device for a long period of time, keep your battery at about 50 percent of its charging capacity and turn the device off to prevent the battery from unnecessary use.
9 Install any updates to your operating system to keep up with the latest battery efficiency enhancements.
10 Do not overcharge batteries.
Stop charging your battery if you see or smell smoke, fluid, other odors or if your battery looks misshapen, discolored, or is hot to the touch.
And dispose of your mobile device, battery and/or accessories properly. Wireless providers and retailers, electronics manufacturers, charitable organizations and state and local waste authorities all offer ways to donate or recycle wireless mobile devices and equipment—often at no cost to you.
11-22-2018 08:06 PM in
Others• Keep the device updated with the latest software.
• Conflicts between running apps may cause the device to heat up. Restart the device.
• Deactivate the Wi-Fi, GPS, and Bluetooth features when not using them.
• Close apps that increase battery consumption or that run in the background when not in use.
• Delete unnecessary files or unused apps.
• Decrease the screen brightness.
• If the device overheats or feels hot for a prolonged period, do not use it for a while. If the device continues to overheat, contact a Samsung Service Centr
Othershttp://apps.samsung.com/mercury/betastore/openAppDetail.as?COUNTRY_CODE=IND&&appId=com.samsung.android.game.gamearena
Othershttps://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=391013
Othershttps://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=391037
Othershttps://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=394335
Othershttps://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=126571
11-22-2018 08:07 PM in
Othershttps://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=406908
Others(This is not my post. Thanks to Amitkumar for share this information with us )
https://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=406866
Othersplease like my post too ❤
https://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=400140
OthersIf my post help you please ❤ like my past and follow me 😊😊😊
https://community.samsungmembers.com/en_IN/post?postId=401718&categoryId=10011&page=1
