About Wireless Charging Device Battery.
(Topic created on: 11-21-2018 09:44 AM)
Raviijangra
Others
Lithium-ion batteries are used in most wireless devices because they are lightweight, can hold a charge and can be recharged repeatedly. Because these batteries are more sensitive than alkaline batteries—like those used in flashlights and other household devices—they need to be treated with care.
 In order to keep your lithium-ion batteries safe and improve their efficiency, we recommend the following actions:
1 Follow the battery usage, storage and charging guidelines provided in your wireless device’s user guide. Do not open your battery pack.
2 Purchase chargers and accessories that are certified, approved or otherwise compatible with your device. If you see an example of an unsafe mobile device or accessory, please report it immediately.
3 Avoid damaging the battery by not crushing, puncturing or putting pressure on it.
4 Keep the device away from heat sources such as direct sunlight and cooking surfaces. Sustained hot or extremely cold weather or temperatures can also impact your battery’s performance.
5 Keep the battery away from other metal objects like coins and keys since they can impact its electrical connections.
6 Avoid exposing the battery to water, which could cause corrosion.
7 Avoid dropping your device, which could potentially damage the battery.
8 If you plan to store your device for a long period of time, keep your battery at about 50 percent of its charging capacity and turn the device off to prevent the battery from unnecessary use.
9 Install any updates to your operating system to keep up with the latest battery efficiency enhancements.
10 Do not overcharge batteries.
Stop charging your battery if you see or smell smoke, fluid, other odors or if your battery looks misshapen, discolored, or is hot to the touch.
And dispose of your mobile device, battery and/or accessories properly. Wireless providers and retailers, electronics manufacturers, charitable organizations and state and local waste authorities all offer ways to donate or recycle wireless mobile devices and equipment—often at no cost to you.
22 Comments
KulBoy
Others
Good info buddy.
Others
thanks kulboy
Others
Make Samsung community health.
please like my post too ❤
https://community.samsungmembers.com/en_IN?projectId=0&meta=#/post?postId=400140
Others
http://apps.samsung.com/mercury/betastore/openAppDetail.as?COUNTRY_CODE=IND&&appId=com.samsung.android.game.gamearena
Others
Steps for Camera troubleshooting do the following steps.
If my post help you please ❤ like my past and follow me 😊😊😊
https://community.samsungmembers.com/en_IN/post?postId=401718&categoryId=10011&page=1
Others
Follow the below points to track your lost device:
● If you have configured Samsung account in your device and activated  Find My Mobile, Remote Control and Google Location Service, then you can track your lost device.
1Logon to https://findmymobile.samsung.com
2Login with your Samsung id and password. Or if you have configured Google account in your device, then you can login with Google id and password on https://www.google.co.in/android/devicemanager .
 ● You can ring, lock or wipe the data from your mobile. Note- Internet must be activated in the device to use the above features.
 ● Also if you have activated SIM Change Alert feature in your device , then you will receive a message on the numbers which you have saved in the feature if a new SIM is inserted in your device.
Others
Your device can flash the rear camera light when you receive any notifications or when alarms sound by activating Flash notification alert.
Navigate to Apps → Settings → Accessibility → Hearing → Enable Flash Notification
Others
Why is the red LED indicator on?
The LED Indicator is turned on while the battery is charging, when you have notifications, or when you record voice memos.
If you don’t want the LED to be used, please deactivate this feature.
Go to Settings > Display > LED indicator.
Others
