what's going on with s7 edge battery
(Topic created on: 09-09-2018 03:31 PM)
arup767
what's happening to Samsung....development team.... it's been repeatedly told by consumers that after the July update for s7 edge. The battery drain issue in s7 edge is constant threat coz after may 15% battery percentage it drops to 0 or 2% or some time even switch's off automatically.... here's some bettery stats 2344e308-9a89-45a7-a96e-46b6b0c3b59f.jpg
6 Comments
arup767
phenom.... please check the stats, as it indicates some time it automatically dipped to 2% directly from 40%.
darshan98
this happens when your battery loss it's capacity by considerable amount. This is the reason why apple was slowing down their device. You can replace battery of your device to solve issue. Tap like if you liked my ans.
arup767
darshan98.... I bought the Samsung s7 edge last year December...brand new 128gb variant.
EKRONtechno
#EKRONtechnology
No Problem On Your Phone Battery
Jackie1982
https://youtu.be/kLxcEFF78do
admin_
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
