storage problem
(Topic created on: 11-17-2019 07:56 AM)
gerardjethro
Hi Im Dennis bautista from philippines, im using know samsung s10 128 gig, i almost delete the samsung apps, to save storage, the apps remain on my phone is samsung member, pass only
11 Comments
littleboy
some apps are pre- installed from the factory itself so you can't uninstall it,
gerardjethro
any reaction if i delete some apps, i wonder if i delete some apps like samsung health and goal, auto pass, my worries i might hang up my phone
EzEr4tin
no worries.. incase mdelete mo yang mga apps na yan available for download nmn yan s playstore or galaxy store 😉
littleboy
go to internal storage select android than select to delete the data, so that you can save some space,
RyoSan
my dear, you are pooking for few gigs while you are able to use SD card, just transfer pics and videos to SD card this will give u alotta of space
gerardjethro
thank u so much
aramis
default apps cannot be deleted.. man.. u have 128 GB.. which data did u save their. if all are multimedia then just use an sd card
gerardjethro
i almost delete the samsung health,goal,paybills only sir wait i almost forgot i also delete galaxy wear bcoz i dont have the watch hwhwhw
Samsung_specialist
Hi Dennis, try to save the multimedia in the SD card. If phone memory is still full and you have less apps, then the device may have a corrupted memory. Therefore, we would recommend to format the phone but make sure to back up the important data first.
Thank You.
