samsung s22 ultra sensor problem
(Topic created on: 07-15-2022 05:33 AM)
mo37
i have  Samsung S22 ultra. My proximity sensor works perfectly fine for calls. However, the issue is with whatsapp audio , the audio still going from the loud speaker and the screen doesnt turn off please help
3 Comments
Samsung_specialist
Hi,
For assistance, please visit one of our authorized Service Centers to check it for you. You may refer to the link it will guide you to the nearest service center to your location https://www.samsung.com/ae/support/service-center/
AHMEDHASANJoY
Der I am all so using s22 ultra please Der software update IMG-20220312-WA0000_1908_1649705573.jpg
Salah2562
I suddenly had the same problem.
Is it from whatsapp or the device?
