samsung please help me; query for S9 plus Charger
(Topic created on: 07-24-2020 11:38 AM)
NitinDelhi
I want to buy S9 plus charger through online. But on your online shop there are two types of charger 1. 45W and 2. 25W. Your assistant on whatsapp told me that my charger is 18W (photo attached). Now from where i can buy it?
And if i bought 25W charger. Will it effect on my S9 Plus?
Please assist me ASAP. as i want to buy it today.
My pincode is 110032 in delhi, India
17 Comments
Kairu
s9 plus only support 15w
NitinDelhi
then why this charger is 18W. it comes with the box when i bought it.
Kairu
15 to 18 watts only
Your charger is 18W adapter. The 25W charger will still charge your device at 18W since your device doesn't support charging higher than 18W.
NitinDelhi
ok thanks
Goldychahal
the chargers came with s9 s10 series are of 15w only....
NitinDelhi
then why the are selling 25W and 45W?
Goldychahal
they are selling 25 and 45 because some other newer samsung devices supports these chargers like note 10 series and s20 series..
Sir The Charger Is 15 Watts As per the photo.
Power = Voltage X Current
9 X 1.67 = 15
Anyways, Even if you buy the 25 w charger the phone would only use 15 w of power
