s7 edge home button do not work
(Topic created on: 03-13-2017 11:31 PM)
sleeker
home button does not work sometimes at all since i got the new smartphone ,gave it in service centre they claimed they replaced entire display .for 3 days it worked perfectly ,after that it became worst.
4 Comments
Himanshu
Can you please try one time Hard Reset of your Device.
Power Off- Then Power on & simultaneously press Power Button+ Volume Up+ Home Button
See there Clear Cache/Factory Reset
Now Just do that & whether it works or not.
sleeker
just did that .but still sluggish
sleeker
still gets non responsive after some clicks.
Samsung_India_
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device performance may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
