s7 cell standby battery issues.
(Topic created on: 07-10-2018 02:36 PM)
jitajitkr
hey there, anyone noticed cell standby battery consumption in s7 after updating to Android 8.0. my phone's cell standby uses more battery compared to any other apps.
if anyone facing same issue then please complain so that company fix it as soon as possible.bf4393d7-5913-4141-aa0a-3192793c7bc6.jpg
8 Comments
sonijiS20p
same issue with my phone
subham0001
Kshiti8097
I am using s7 edge, running 8.0 update. is it problem? I am not facing battery heating issue but seems standby is consuming battery. is it normal as per standard or a problem?53d47fc1-62ab-42c2-92d7-3d3094244c54.jpg
jitajitkr
it's problem.
Note10plsUser
cell standby isn't good as it used to be... I'm also facing the same problem
Rishi0007
they haven't given any update after oreo update. So wait for the FOTA update which will fix all these issue
jitajitkr
please call samsung customer care 1800407267864 and request to Samsung software developer to fix this
admin_
Thank you for being a part of Samsung community. We apologize for the battery issue you are facing in the device after the update. Please provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
