s21fe ka battery backup acha karna chahiye and improve camera
(Topic created on: 01-24-2023 06:29 AM)
harvindershin
Samsung sunlo battery backup improve karo software update se
8 Comments
Kuldipindia
S21 fe se S20 fe ka battery backup achha hai
harvindershin
Pehle theek tha but abhi thodi prob aayi update ke baad s20fe mein snapdragon processor hai is liye backup acha hai thoda
piyussh07
Kitna backup milrha hai? Sot?
harvindershin
Screen on time pehle to theek tha 5 hour plus tha abhi thoda down 4.5
piyussh07
Mujhe phle less than 4hr milrha tha, last patch k baad 6hr+ milrha
harvindershin
Standby mein bhi thodi battery jada consume ho ri agge se
Front camera ko update ki jarurat h
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
