Resolved! Solved
s20 heating issue while using camera
(Topic created on: 03-17-2020 08:28 AM)
divzz
I am in very much pain regarding this issue #HEATING.Every morning i got up and i find that my phone is heated up. And while using camera only for 3 to 5 minutes it gets too much heat up and drain too much battery  in few minutes.
Resolved!
divzz
my device is 18 days old did i get the exchange
Subhra68
how did you get the replacement it's very annoying.  Whenever I am launching the camera app it's heating like crazy.
s20pluscamera
20 plus after may update also facing same heating issue and battery drainage
AravindanR
My S10 also gets warm when when using camera, I think most of the flagship smartphone does this.
divzz
no brother same device with snapdragon processor does not have this kind of issue.
cs_member8
Dear Samsung Member,
Kindly follow the below steps and be assured your issue would be resolved:
1. Close Background Apps: Tap minimize key & close the background running application.
2. Usage of mobile phone when charging. We recommend you to avoid usage of mobile phone while charging.
For more troubleshooting steps kindly visit the below provided links to resolve the heating issue and the battery draining issue :
1. https://www.samsung.com/in/support/mobile-devices/why-the-heating-issue-occurs-in-mobile-device/
2. https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance register your concern in Samsung member application: Samsung member > Send feedback > Error reports/Ask questions.
s20pluscamera
20 plus after may update also facing same heating issue and battery drainage  i even format my device completely and update to may update patch,
still camera heating and battery drainage isseu.
minimized my apps also which is use most.
vsekhar
no bg app running , etc checked twice ,and still device get burns quickly while when Camera works
prakamya
every case you reply with the same thing and nothing works at all it still heats up like helll
Kikaytrekkie
When you fell asleep while charging then you're not using it while charging. IT STILL gets hot.
