Resolved! Solved
overheating issue- S10 plus
(Topic created on: 05-11-2020 10:53 PM)
iAnshul
My s10 plus is almost 11 months old. It has suddenly started overheating. It heating starts near the Bixby button. I have already tried switching the device off and on, soft reset and wiping the cache. How to resolve the issue?
2 Solutions
Jiyodilse
heating problem is normal now in summer days due to hot atmosphere it occure
For heating related issue you should follow my stuff ..may be it will surely help you...
https://r2.community.samsung.com/t5/Galaxy-M/Overheating/td-p/3994707
7 Comments
hedgehog
main reason for all to fail is bug instability you can either wait for next stable update or follow some advice and tips I could give you
1 use adaptive battery
2 use medium power save
3 prevent background apps from consuming data in battery device care
4 put unused apps to sleep
5 reduce some permissions given to apps that are not necessary for running of app
6 use dark mode
7 use location when necessary as in maps Google search or any location based app else constant use loads battery causing heating
8 prevent network inputs like NFC bluetooth WiFi from working together too many network inputs will cause heating and lagging
9 while charging keep phone idle
10 turn off auto sync use when necessary
11 reset phone settings once clear cache
12 if nothing works once try factory reset
13 charge in cool conditions as outside weather will be hot these days
14 dont use vibration if not necessary
15 use accubattery for complete battery diagnostics
I hope this helps because one ui bugs can be fixed by samsung when new updates come till then try these tips they could help to reduce battery heat up and loading so that smooth charging works and device runs smoothly
Vikki101
put unused apps to deep sleep and charge your phone only till 95% don't charge till 100
and restart your phone atleast twice a week
if still problem persist do a hard factory reset
iAnshul
Thanks both... let me try and see. will seek help if your solutions fail (which i hope not).
Saranyaa
Hi Anshul,
Is your overheating issue with S10 plus resolved? Did you approach any service centre? My s10 plus is 1y old and having the same heating issue for minimal usage. No luck even after factory reset and wiping cache partition.
iAnshul
hey Saranya!
luckily i didn't need to take it to any service centre. wiping cache did fhe trick for me. its getting heated now and then but thats due to weather and high perfomance usage like gaming. If your issue is not resolved, i suggest to take it to a service centre ASAP.
Jiyodilse
arunnechlani
